anyone using detachable tripod legs?
Is anyone here using the old set-up of detachable tripod legs fixed to a revolving metal ring on the bottom of the camera? If so, can you tell me how easy it is to adjust the camera when composing a photograph? The reason I ask is because I'm thinking of making a camera and wooden tripod which used this principle, i.e. do without a tripod head, which could potentially lead to greater stability.
So , it’s mostly different from using a “modern” tripod because the legs are free to swing , very free so a light push will lift the nearest leg and allow you to reposition as long as the foot of the leg has a decent grip on the ground , imagine on a polished floor you will need squash balls fitted to the spikes. Sometimes you will see a cord attached to all 3 legs to avoid the legs splaying it’s a good idea , possibly do this with detachable karabiner type connections otherwise with 3 separate leg sets it will be a pain. The almost universal design of the top pegged 3 section legs is worth studying as they pretty much perfected the strength/weight , the tensioned top struts are made specifically to reduce twist , with out that tension the camera/ring will be much less stable , I think they are made of a specific wood as well possibly ash? I always like to think of wood as the original carbon fibre because it is.
May not be relevant but if doing away with the head is your main objective then have you considered a leveling head? Not really a head at all but a half ball that gives 15 degrees of tilt in any direction which is usually enough for levelling.
Thank you for your reply. So it sounds like it is possible to easily align the camera with the set-up being discussed. Not surprising really as it was used by some great photographers - including Sutcliffe when he took his wonderful portraits.
Yes, I know what you mean about how the tensioned top struts of the tripod legs work. And, yes, the wood of choice was Ash. Fortunately I've got plenty of it. And it does have a damping quality, as you infer, like carbon fibre.
Thanks; I wasn't aware of these. But I was thinking of something with a bigger area at the top of the tripod, for more stability.
They are available in different sizes. I think I've seen them up to 90mm. Mines a 60mm and supports my Toyo G (5Kg) no problem. But I understand it may not be what you want.
I can see how this would work for you, and I might even get one as it would be a more rigid alternative than using my B&S head. But, yes, I was thinking of something wider. I'm thinking in terms of a wooden disc with a diameter of about 140 to 150mm, with the tripod legs permanently attached to its perimeter.
You've reminded me of a Seagull camera I saw in a street market in Hong Kong once. It had attached legs. It had a metal ring fixed in the bed that the legs were attached to.
The detachable legs take a little getting used to, and you can't tilt the camera much. My Gandolfi half plate camera came with a light weight wooden tripos which is robust in terms of stability, it needed repair, but that was relatively simple. I have an advert for it in a BJP Almanac (it's not a Gandolfi tripos).
You could make a Gandolfi style tripod the smaller ones are light and very stable. It appears they are derived from earlier camera stands, but with folding and extendable legs, this from an 1898 Ross advert.
Looking at the 1898 Almanac what are referred to on eBay etc as adapters are in fact part of a tripod set and sold with the set of legs.
Ian, yes, your second photograph shows the kind of thing I had in mind, but with the camera sitting on it and rotating. Thanks.
Still not sure if the set-up would allow enough camera movement up or down....So I'm still thinking it through, and have other options.
Here is a link to Mr Wandel who makes many things but as he describes making wooden tripods a few years ago - always interesting if you are interested in woodworking.
Yes, I have made two designs of three leg tripods out of ash and aluminium. They were 4 section, made to suit the Thornton Pickard type tripod ring. I could have got a 3 section original TP tripod or similar off ebay (eg Ashford 'Giraffe', or one of the Graflex Crown sizes), but I wanted the tripod to be short enough to fit onto a bicycle when collapsed and be lightweight (1.2kg) but also extend to at least 5ft6". Adjusting the position of the camera wasn't quick (for height and laterally) but the stability was acceptable and the appearance matched my camera better than a modern tripod.
Ashford's "Giraffe" uses a different design to other tripod legs, making them small, light, and taller.
The Giraffe legs, and folded compared to more typical legs.
Thanks for posting. You say adjusting the camera isn't quick, and the stability is "acceptable". I must say I'm having second thoughts about my original idea...
