Wide Angle Lens coice.
I haven't had any issues when using my 79mm f5.5 Super Angulon with my Wista 45DX, it's on a flat board. However with my 65mm super Angulon I have to tilt the camera to prevent the front of the base being in the image.
How much rise/fall have you got to work with when the bellows are compressed that much?
With my 65mm SA very little, but then technically it doesn't quite cover 5x4, but in practice it's fine if used with care. With slight front tilt there's still enough flexibility in the bellows to allow the slight fall needed to remain within the image circle.
It's far easier to set-up and use the Wista with the 65mm than it looks. I can probably count the number of times I've used the lens, maybe a dozen times, but with a high success rate in terms of images for Exhibitions, images I couldn't make with a longer focal length.
