Ideas on equipment for field trips ?
Barney
I have been thinking that a shooting stick might be handy as a seat at a valuable height, save the back on setups, anyone tried one and was it beneficial?
As "less is more", then a minimum of gear wil save your back, so no shooting stick (which needs to be hauled too) needed...
Its not heavy in the car, 200 yards maximum to subject. I need comfort when composing and adjusting movements. A shooting stick seems just the right height.
I think the shooting stick works if you are static , start leaning g moving your head/arms around and you will need a good sense of balance and agility to be stable and comfortable , head under dark cloth could be disorientating .
I guess it could be about comfortable posture and tripod height? This could also be a bit of a pain as height for standing and sitting on shooting stick would be different and cause further stress to the posture.
Can always try one I suppose , I know I always need the camera higher than sometimes expected to be comfortable .
Low camera and a chair requires a good spinning head - possible but beware of leaning forward to compose on the screen.
Being tense and stressed is going to exacerbate the situation - there is a lot in the mix .
With the proviso that I've never actually tried one in the field, the Walkstool from Ffordes might be suitable for you?
I've owned a few of these things for over 25 years, I have yet to use them :D I inherited them from my youngest sister, they are light weight but I tend to shoot fast, sit and relax after on something nearby or the ground and soak up the atmosphere. I really don't want to carry anything else.
But if Barney takes his new De Vere out in the landscape he will definitely need to stop and regain strength every 5 minutes, maybe do some heavy weight training.
More seriously for wildlife shooting, trainspotting, where you you may have to wait patiently, they would be useful.
Its alright for you, :) you shoot 4x5 faster than I can shoot 35mm. :)
Adjust after a quick look at the scene, snap. Done.
I have to look/adjust.................... look/adjust............... look/adjust.....................for about for 20 minutes, and it is still wrong. :)
