- Oct 17, 2023
I paid top dollar for but, a fair choice for a 4x8" camera?
Have you read my rantings about auto-correct?You don't have a 4"x8" camera
It's an extreme wide angle that covers 10"x8" stopped down to f22 with little room for movements, I have two 120mm lenses for LF, a 1912 Dagor, and a 1960s Angulon, bot f6.8, they are more useful for Half plate/7x5, although excellent on 5x4. They are also small, and light.
I've always preferred a reasonable gap in focal lengths in my set-ups, with LF that's 150mm, 90mm, 75mm, MF 80mm 45mm, 35mm 50mm, 28mm, 19mm.
I think there's nothing to worry about there. It'll have less than a 90mm, and even then falloff with a 90mm lens of the biogon-type design (basically all big common-or-garden 90mm lenses) is negligible on 5x4" even with chromes. It's not till you get out to 5x7" or 6x17cm with a 90mm that it gets significant.I'm hoping corner shading will not be an issue given I'm using it on a 4X5.
What aperture?We use a 72mm lens on 5x4 and with a fresnel, don't find it a problem.
It is a 120I would say its a bit of a handful for 5x4 , big and fragile for when you want to travel more lightly with the “tiny” Tachi. , a 120,135,150, Or 180 would be more portable and with care the shorter ones can be stored reversed in the camera folded I think , it works on my Wistas. I picked up a Yamasaki Congo SW 120 5.6 recently that will cover 5x7 bit rare but good movements with 5x4 physically small. There is a 120 Rodenstock 5.6 only made for a few years but relatively modern and inexpensive .
I think there is a very narrow choice covering both formats sensibly outside of the studio.
I need affirmation.That Nikon would be very nice for 5x7 use with plenty of movements. Wouldn't mind one of those.
