A
acrobatic_citron
Guest
Hello
Scouring the web including this here wonderful forum I've read different answers for the min amount of stock dev required when using D23.
My plan is to standardise on D23 across the 3 Foma films
Is there any documentation from Kodak or other that states it?
The consensus seems to be 200-250ml per 80sq inches (4 4x5 Sheets) so at 1:1 in my Jobo 3010 I'm looking at 400-500 ml total per 4 sheets, does this sound correct?
As for times, its mentionoed roughly double the times when diluted as a starting point and also use d76 times in no d23 time available, however looking at d76 times for stock and 1:1 are not double.
So after all my waffling, anyone using d23 what amounts do you use and if using foma or not what recommended starting point?
I'm thinking Foma 100, d23 1:1 @20 degrees for 10 minutes to start, rotated on a old beseler color base
Thanks!
Thanks!
