Sun prints from negatives.
Keith tapscott.
I have just found an old unopened box of Multigrade IV RC paper 5x7 inches.
I would like to try making a sun print from a 5x7 negative.
Does anyone have any idea what would be a good starting time for exposure?
I am guessing it would be a few hours or so.
Thanks in advance.
It's a little while since I made any lumen prints, but from memory an hour in bright sun was enough where the images was made using natural materials such as flowers, on RC paper. I tried a couple of prints from negatives onto fibre paper, with an exposure of 2-3 hours, but the resulting image was low in contrast.
I should try again in this sunny weather.
Thanks Kevin. I tried it yesterday and gave just over 8 hours exposure.
The image was very soft and light and sort of a pale brown in colour.
Anyway, it was an interesting experiment.
Hopefully better luck next time.
Thats odd, I've done cyanotypes from printed acetate negatives that only needed about 30 minutes exposure. I thought cyanotypes were supposed to be a little slower than ordinary photo paper.
Bright sunshine also strikes me as quite a bit brighter than any enlarger I've used.
Bright sunshine also strikes me as quite a bit brighter than any enlarger .
Sun prints are self developing and from what I have just looked up online can sometimes take days to expose satisfactorily.
Anyway, it was fun to try.
Perhaps someone here who has experience of producing Lumen prints could chime in.
You can make any silver gelatin photographic paper give good Lumen/POP print by coating the paper with a sensitiser that makes the silver halides respond more favourably to UV light. There are two simple sensitizers that work well for this purpose: i) silver nitrate and ii) sodium nitrite. You can use either of them.
To coat silver nitrate on the photographic paper, soak a cotton ball in 2% solution of silver nitrate; squeeze out the excess liquid; wipe the paper with the cotton ball using parallel strokes from left to right; rotate the paper by 90 degrees and wipe again; rotate the paper again by 90 degrees and wipe; rotate the paper one last time by 90 degrees and wipe. If you find later that the density is lacking, you can coat the paper twice with 2% solution or use a stronger solution.
To sensitize the paper with sodium nitrite, prepare a 10% solution and float the paper with emulsion side down for 5 minutes; take out the paper and let it drip excess sensitizer into the tray; hang the sensitized paper to dry. You can reuse the nitrite solution several times.
Please use gloves and wear protective eyeware while handling the chemicals. And take all necessary precautions as you would with similar processes.
Exposure time varies with paper and light source. Usually 30-60 minutes in open shade. You can always check the printed-out image during exposure and extend the exposure if required.
The tonal scale is long and hence best results are with negatives that have a density range > 1.5.
