Retaining Ring for Copal 3 lens?
jhotopf
Does anyone know where I can get a retaining ring for a Copal 3 lens, I believe the right one is an M62 75 in the UK that is in stock? Are they all sized the same, the ring would be for a 300 W f/5.6 Fujinon lens.
Try boyaetone16 on ebay they sell rings for lens/shutters...or search ebay
LATE EDIT:
I should have pointed out this is a Hong Kong Company but goods seem to turn up from Birmingham UK in a day or two...
I buy off the seller mentioned above. No problems, usually Fresnel screens.
It's very possible the shutter is actually a Copal 3S, which is M61x0.75. All the Fujinons I've seen in Copal 3 shutters, admittedly a small sample, were actually in Copal 3S - Copal weren't consistent about shutter markings and I've seen "3S" shutters marked only as "3". You're best off measuring the lens once you have it in hand.
I got it from the boyaetone link yesterday, good to hear to arrives quickly.
Knowing my luck it will turn out I need a Copal 3S retaining ring, just have to keep my fingers crossed on this one! I'll have to measure the thread on the lens itself which will be fraction more than the ring itself.
Thanks, I’ll keep this in mind should I need the 3S ring
