- Oct 21, 2020
Well it all started nearly four and a bit years ago when I decided to have a crack at building a 5x7 camera ... went to all the trouble of researching and making a 5x7 set of bellows. I started with the bellows because if I couldn't make a good set then there was no point in making any other parts!
Well the bellows turned out rather well, but my Kodak Specialist dropped into my hands so to speak shortly after I built the bellows ... so I shelved the project to get on with shooting that.
Fast forward a couple of years, and I was really starting to get the itch to try 10x8 and having cut my teeth on a 5x7 bellows I made ... I think ... an even nicer job of a 10x8 set. Unfortunately the fates weren't smiling on me, and the pressure of my job ... coupled with trying to turn out weekly episodes of my YouTube channel - and a health issue that limited my ability to walk without lots of pain - caused a big case of photographic 'burn out'. I pulled up the drawbridge and shot very little ... or just digital for a while. Sometimes a rest is a good thing.
Anyway the film cameras have been out again and I'm feeling a renewed energy for large format ... and I pulled the 10x0 bellows from its safe storage and decided to crack on! If anyone wants to see my two channel episodes on making bellows they are here and here.
As luck would have it, a little while ago my large CO2 laser cutter got a power increase - I blew a tube and a power supply - and so fitted a more powerful tube and matching larger power supply. Here's the laser ...
All this leading to me being able to munch through 9mm ply like lightning - so I decided that that would be my building material of choice.
It made short work of bellows frames
The spare glue on the bellows seam cleans up well with a bit of isopropyl alcohol on a cotton bud ...
Frames fitted ...
I finger jointed the front and rear standards ... here they are glued but not cleaned up yet ... ultimately I'll use black stain and gunstock oil for finishing. You can see the 'optical bench' part ... that is the focus mechanism taking shape ... all based on CNC machine parts ... taking a leaf out of Intrepid's book
The focus unit nearly complete ... the rails are over length and I'll have to prime up me angle grinder and chop those stainless steel rails ... a hacksaw won't even scratch them!
To be continued
Frames fitted ...
To be continued
