- Aug 6, 2016
Rob, I did a video on using the Fluid mount, excuse my Yorkshire accent
Martin. You do very nice work. I started shooting 4x5's a year ago and upgraded from a V600 which I used for 35mm and 6x7s, to a V850. Here are some samples of 4x5s but they are all done dry with the V850 holders. How would you compare your wet mount scans to dry? Thanks. By the way. I'm from The Bronx in New York City, and my wife is from Brooklyn. So, your accent sounds more like English than either of ours.David, I use their AN glass on the Epson fluid mount, hinged with tape as in the video, and on the Nikon 9000 120 holder. Works extremely well on the Epson holder, however, on the Nikon 120 holder it keeps the negs flat but I found I got what I can only describe as edge burn between the frames spaces, I managed to pick up a Nikon glass holder with film masks that cured that.
Flickr Search
www.flickr.com
To be totally honest Alan, I have found very little difference between the way I mount the negs on the Epson, resting glass on top, which in turn keeps the 4x5 negs totally flat.
Using the wet method can be beneficial if the negative have scratches and it will in some cases help in minimising grain, also if you are doing big prints you might see better detail, other than that , I use the dry method 95% of the time mounting the neg as in my video
Martin
Kodak says that their Ektar and Portra films are made for scanning. I don't know what they have done to make it easier or what shows up better.Wet mounting negative goes back to at least the 1920s. I have a short extract from a longer article in the 1927 British Journal Photographic Almanac.
Surface artefacts affecting the gelatin super coat can increase apparent garininess, this was more of an issue with older softer emilsions but can still affect some films Fuji Acros being one of the worst. Poor temperature control greatly increases these issues, at it's worst it's oftencalled micro or incipient reticulation. Kodak preferred the term "Surface Artefacts"
Ironically scanning rather than conventional optical enlarging can increase the apparent graininess from surface artefacts and this caused issue with early digital minilabs and Kodak colour films. This lead to changes in Kodak's emulsion hardeners in films and also colour papers. You can see references in currentKodak data-sheets to improvements for scanning.
Ctein used to wet mount his negatives for optical enlarging.
I can imagine two things they could do.
They might make small adjustments to the dyes used, to bring them more into line with the sensitivities of scanners, rather than of paper. Clever stuff if they can do it without us noticing.
Or they may pay attention to the micro-texture of the surfaces, to reduce Newton’s Rings. Beyond that, my brain fails.
