- Aug 6, 2016
Gamma 0.9 sounds extremely high... He wasn't doing alt UV based prints?
The density of 0.9 was for the highlights not gamma
Just been reading an article that @thronobulax made on hs findings with PyroCat and EMA which was intersting. I noticed that the dilution used was 1.5:1:150.
The dilution I used when trying this system came from the Steve sherman video series and was 3ml of A + 2ml of B which I belive works out to something like 1.3:1:200
The only part of his process which bothered me was the fact that he was designing a negative to give him a density of 0.9 which he then used a lot of blue light from his Ilford Multigrade 500H Enlarger Head to control contrast.
Afrer seeing this in action, I sort of stopped tinkering with this EMA simply because I only use a standard enlarger so I am wondering if you also use a Multigrade 500H Enlarger Head @thronobulax
I find that this gives me full box speed and good pronounced edge effects for those films that respond to this technique (not all do, at least not well).
@thronobulax with the above system, how do the negatives look to you in terms of density in the high values. Would they in your opinion be suitable for scanning ?
Out of the films you have tested, which would you say are not that well suited
I continue to find that I somewhat prefer the "look" for stand processed negatives over EMA.
In my experience, (semi)stand delivers full box ASA, manages highlights via exhaustion, and provides expanded mid-tone local- or microcontrast.I'm curious to learn what differences you found in the results obtained from stand developing vs EMA.
www.5x4.co.uk
gitbucket.tundraware.com
The example you cite doesn't really help your cause. Just thought you need to know because it's probably the way it has come up on the screen. The image is not sharp. And it's low in contrast. The shadows are black where you would expect to see some detail. And there are no highlights - the area at bottom left which you say is a blown highlight from the scanning process isn't anywhere near white. It's a pale grey- not much above mid grey in value.
I am sure your original print isn't anything like this, but the image as it appears on screen won't win anyone over to EMA development.
To be clear, they do not look unusually bright or dark?I think they look like you intended them to look.
I'm not sure if it is a monitor problem. The image in question is too dark on my screen. An earlier one you posted was too light. And your image in the first post of this thread is fine, in terms of brightness and contrast...
No criticism intended. I just think it's a pity that I, and others, are probably not seeing an accurate representation of your photographs.
I agree with your assessment entirely. He is designing his negatives for his particular subject matter and vision. Also, the way he prints is different than me and requires a negative that works that way. I am split VC silver printing. I believe he is contact printing - perhaps on Platinum or Palladium? - not sure.@thronobulax: Thanks for sharing your insights.
Interestingly, Steve Sherman doesn't seem to be targeting full film speed with EMA from what I understood reading his unblinkingeye article. He likes to generously overexpose and underdevelop. Of course, it doesn't mean that one shouldn't use EMA to get full speed like you do, but the tonality might not be the same. Any perspectives on this?
An excellent point. I am going to have to figure out how to tell Vuescan to produce that profile when I scan.If you are referring to the image at the beginnig of the post from @thronobulax then the discrepency may be because the scanned image does not have an embedded profile which is going to make it difficult for browsers to render it properly.
Not sure to whom this addressed.An observation, after shooting many hundreds of rolls of 120 Fomapan 200 & 100, and many boxes of 5x4 and larger, why are you messing about trying to achieve something that's consistently giving you poorer results. It doesn't make sense.
