JCB ALTERNATIVES PLEASE
Camerashy
The famous "JCB" Joe Cornish Boulder is an option, but what alternatives do you use to create depth in your photographs?
The obvious strategy is an out-of-focus background, but LF photographers seem to prefer sharpness. Contriving to have leading lines in the composition will help, but this implies a subject with the right kind of structure. Placement of the horizon might prove useful. If there is one. A good deal of sky suggests distance.
It doesn’t have to be a boulder of course.
Landscape painters used to include a human figure contemplating the scene.
I didn’t know it was the property of Mr Cornish, but the typical arrangement is to use a wide-angle lens and place the camera low down and close to something in the foreground, exaggerating its size in the image. Almost always, a bit of front tilt is needed.
Yes, wide-angle lenses definitely need foreground interest. Although I often prefer a higher taking position to create greater separation between objects.
And indeed, subject scale is a natural choice too.
It's not something I consciously think about when out shooting.
You can use DOF to convey depth as well
I don't think you absolutely ned a wide-angle lens for this sort of thing. These were taken with a 210mm.flooded path.jpgold wall hamer bridge.jpg
Any idiot can stick a rock in the foreground of an image. The difficult part, which Cornish was a master of, is in arranging a balanced composition where the foreground links through the midground into the background in one satisfying whole.
To me, the pic from #9 looks total different, I can't see a balanced composition.
It's not a Joe Cornish photo as far as I know.
That specific round boulder at Elgol, conveniently situated about 1 minutes walk from the roadhead, is known for featuring on the cover of First Light, which people have then tried to ape/copy.
Beyond that, a certain clique of Light & Land hangers-on in the 2000s-2010s were using the term "Joe Cornish Boulder" to refer to any prominent foreground rock.
