5x4 street portraits with half-frame adapter
Last weekend I tested out a half-frame adapter I've had for many years but never got around to using. This is a police mugshot adapter made by Graflex which I used on my Speed Graphic. It came in an auction lot with a 3x4 Graflex Super D but the adapter is for a 5x4 camera. It's not a universal design and only seems to fit a speed graphic.
Anyone want to guess the lens? Focal length will do. I used two different lenses for these shots. All on expired Kodak TXP 320 (ISO 200), developed in HC110 1+31 in a MOD54 adapter because I didn't want the lines I'm getting when using a Jobo 2509n.
That's one of the lenses I used. I thought I'd help you with the file names :p .
Rumbled! I do own that exact lens though so maybe at a subconscious level I recognised it.
Haha. Which shots did I use the 150/2.8 on?
I thought 2 and 4.
That's why I went for 1 and 3 For a 210mm.
It would make more sense to me that a shorter lens was used for the wider shots and a longer lens for the tighter crops.
I thought 2 and 4.
You're half correct. I will give you a clue. Only one pair used the 150/2.8. The others used a different lens. It wasn't 210mm. Guess the focal length and for extra bonus points the lens maker :)
1+3 are the same lens 150mm f2.8?
And 2+4 are the same lens, I'm guessing a 13,5cm f3.5?
