That looks great, Martin. It looks like it would be a good negative to use for an alternative process such as a Cyanotype. You probably know this already, but you can enlarge via a scanner onto OHP film to make a larger contact print. This also avoids damage to your original negative during contact with the paper.
Another thing that can be useful for still life is a set of close-up lenses that screw on like filters. I tried these recently, and was pleasantly surprised with the outcome. The 150mm lens I use has a 49mm filter thread which means the close-up lenses were cheap.
Alex
