De Vere Devon Camera
Barney
I have just purchased this camera on an auction site based on a top view of a box of bits, It has interchangeable backs for 4x5, 5x7 and 8x10. Anticipating some repairs/modifications/overhauling does anyone have any info concerning documentation or resources for this camera model?
The interchangeable backs all look present and in reasonable order, there also appears to be a lens attached, but the photo of the system does not provide much info really, pretty much purchased on a wing and a prayer.
Big and heavy, I had the Whole plate version with two addtional backs, Half plate & 5x4. Essentially quite simple construction so easy to service, restore.
I had to get bag bellows made to use a 150mm lens, Custom (CAmera) bellows had the pattern so made them for me.but I had to make the fixing plates. Lens boards are flat so easy to make from Aluminium.
Thanks Ian,
Basically I need/want it for the 8x10 so that I can produce larger negatives for Kallitype prints, so I Anticipate mainly studio type use, where, hopefully, weight will not be a concern.
Well then, a few surprises, it is not Devere Devon, its a huge Kodak
no interchangeable backs, set up for 4x5, but three 5x7 film holders though and a couple of 4x5. Nice surprise is a Kodak Ektar 203mm f 7.7
Bellows look good but creaking like mad !
Ian was right about the weight, its made from inch plywood !
Overall the camera looks to have had very little use with slight deterioration to the coatings of the metal components which can only be expected at almost 60 years old.
The lens is excellent with one spec of dust inside the front element, about half a mm, and shutter speeds look good down to 1/10th and below that are quite slow which is probably a consequence of aged lubricants. I will get the lens and shutter serviced I think. I am surprised reading the Ektar reviews, looks like a good 'un.
That's a Half plate back and will tale 7x5 holders. Soeone has added wood to the inside edges to crop to 5x4.
Ilford dropped Whole plate & Half plate film around 1974/5, last I saw was on my Ilford Professional dealers shelves in 1977. I wouldn't be surprised if your holders haven't been converted to take 5x4 film. When I bought my Spcialist 2 twl holders had a neat conversion to shoot 5x4.
You should be able to remove the added wood, just remove the screen first.
I will try that as the whole back end looks to be 7x5
The film holders stated size are 6 1/2 x 4 3/8 - but that looks image size not film size.
Will that take 7x5 ? a quick run with tape says yes but image may be smaller
The back is Half plate, but as it's an International back it will also take 7x5 film holder, Only the image on the screen is cropped smaller, not on the film.
I have the same back, and also a metal Kodak Specialist 3 Half plate back, which also fits a Specialist 2. The wooden bits are probably just glued in, but check for screws,
7x5 film will fit but can drop out in use with 13x18cm holder. Because 7x5 cameras were never made in the UK (until quite recently) there's very few film holders available second-hand. You need vto buy from the US.
The film holders will not take 5x7 , the back one is half plate , the white painted sizes are important as they are the true sizes - the moulded fidelity size is basically the outer frame size.
Suspect your camera is a whole plate version of the London Kodaks
The Kodak Specialist 2 was only made in one size - Half Plate.
About 4 years ago a UK seller had Half plate holders listed as 7x5, I posted a thread here at the time.
Because most modern International DDS film holders were made in the US they typically carry the US film soze in the moulding at the light seal end, and then the relvant film size if different.
The Half plate ones I saw, Fidelity Deluxe, had the moulded in 5x7, and below 12x16.5cm in white print, which us Half plate. Someone bought them, and they weren't cheap, luckily he got his money back.
There are a few on eBay at the moment, a different seller, but he does list them as 12x16.5cm = Half plate. Japan used Half plate film for a number of years, after it was dropped here in the Uk, and these International 12x16.5 cm film holders were made for their cameras.
Process Supplies sell Fomapan in half plate - out of stock at the moment - I got some last year - can be worth using as you have holders as Ian says actual 5x7 are awkward to obtain here in uk .
Quite similar to my Kodak SI Mark II Ground Camera, except that mine doesn't have the metal protectors on the side of the rails, or the bail back. I'm using that camera in my profile picture.
As well as the half-plate Foma mentioned by @HowLarge, you can also buy FP4+ and HP5+ in half-plate size through the Ilford ULF process. I have some HP5+ in half-plate size sold by Nik and Trik, which may have been a ULF order that the buyer didn't follow through.
You can also get dry glass plates in half-plate size from Zebra.
My camera also has a proper 4x5 back with a bail arm - although I have lighter cameras to shoot 4x5 film with.
Thanks for all the Tips,
I was thinking of getting 7x5 and cutting it down, no need for that now.
Sadly bellows, which look good condition, are like fishnet stockings when tested in the darkroom.
If you can wait till the weekend I will have time to check the bellows on a parts Kodak I have.
Be gentle with the geared front rise brass gear breaks up if cranked too hard
