- Aug 6, 2016
Honestly it's fine when you get used to it. I use both types of camera and don't give it a second thought.The thing I don’t t like on the Chamonix is the central focus system , there are others that use the the same as well, Intrepid being another, much prefer to focus with my hands outside the camera, just seems a very awkward way to work
Exactly as Dave_P said, I use both types of focussing designed cameras and I don't give it a second thought. Where I prefer the rear focussing is when I'm not using any movements at all because I've made a dark cloth which is like a big t-shirt where I insert my arms into the sleeves, one hand holding the loupe, the other focussing and my head through the neck opening. This design of dark cloth gives me complete black out on the ground glass and works really well especially in bright conditions where light might be reflecting up from the ground or if there's a breeze.The thing I don’t t like on the Chamonix is the central focus system , there are others that use the the same as well, Intrepid being another, much prefer to focus with my hands outside the camera, just seems a very awkward way to work
What I do is just slide the rear standard to the full extension for a long lens, push the base screws into the rear of the slots and push the standard up to them for a 150mm lens, and do the same but with the screws at the front end of the slots for a 90mm. So I never have to rack the focus very far, and I can always in fact leave the front standard in the same screw hole, and the rear is always square to the front.I have found that the central lead screw is excellent for fine focus, but tedious for large movements (as when changing lenses for instance). Would it be possible to devise some sort of clutch mechanism, so that both methods could be used as needed?
This is a hint for other camera designers. I’ve given up making cameras myself.
I'm wondering whether the single focussing knob design came about because it's easier to use than the other design of having to unlock the front focussing knob with the knob on the left, focus with the knob on the right then lock the focus with the knob on the left again? I'm just talking about focussing here, not applying front movements. If I want to apply front movements I sometimes just wear close-up reading glasses to view the image on the groundless without needing to use a loupe. I don't use movements on every shot.Well, people have to disagree, but to me, having your head under the Dark cloth, one hand using a focus loupe and the other outside adjusting the front standard – focusing, tilting, swinging – seems like the most natural way to work. I guess it's just a case of each to their own! I just can't think of one good reason for the focusing screen to be at the back of the camera, other than keeping the weight and cost down. Happy New Year![]()
