Interesting article Guardian Fri 14th...
Interesting. We started to realise that there was more work in printing for other photographers than trying to be photographers ourselves. Although it uses all our photographic skills, both analogue and digital, to get the best results as a print.
Looks interesting, one to watch later. There's a guy with a science PhD who does these in my local camera club from 10x8 negatives. Great to see in the flesh.
Platinum printing using digital inter-negatives is formulaic, once your set-up is calibrated infinitely repeatable. When I lived in Turkey I visited a British LF photographer living near Fethiye to learn how to Platinum print.
The critical stage is the scan and edited digital image, then as long as the printer RIP, in this case QTR, has been fine-tuned you get negatives that print consistently. There are QTR profiles for negatives for varying alternative processes. QTR can also be used for B&W digital printing.
Coating and exposing with a UV light box was straightforward, as was final processing & washing. David had no darkroom, he found it cheaper to make Platinum prints.
Ive tried and failed many times trying to make decent 10x8 digital negatives for silver contact prints. All the books I have read seemed to be geared towards platinum and other alternative proccess
Personally, for anything larger than A2, I send my final TIFF files to Picto in Paris. They use the same Lambda printer that Ilford/Harman use and produce simply stunning prints on their Silver Bromide paper.
I know you would rather create your own prints by hand but…
I don’t quite understand making digital negs for silver printing. Surely you will be starting from a negative anyway?
In pre-digital times I did attend a platinum workshop. Although the process was more fiddly than silver printing, it seemed relatively straightforward to produce a print. Producing a really good one was an entirely different matter.
As I understand it, a digital negative gives the opportunity to create a contact print larger than your original negative.
Also a digital negative might be A; from a digital camera originally, or B; from a negative that doesn't have the required density/contrast for alt processes.
A typical use case for me would be to make an enlargent to 8x10 from my 5x4 negatives
