I did a thing today
Flack
I watched a video a while ago on YT about using B/W chemicals, then also C41 chemicals to process E6 slide film. So today I tried this out on some 4x5 1990 Fuji Velvia 50 slide film.
I used Rodinal for the BW and then Cinestill 2 bath kit for the color part. I did 12 mins at 40c for the BW stage, then a 3 min wash. Then I took the film out of the jobo tank, I did not remove it from the reel. I then exposed it to a video light that is 5600K for 1 min rotating the reel to cover both sheets.
Then it was put back in the tank for developing in the C41 chemicals for the stated time of 6 mins 30 at 38c. for both Dev and B/Fix.
It was then washed for 4 mins.
I have to say I was very skeptical about this process, but when I hung both sheets to dry they looked great. a bit dark over all, but all the colours are there and the image when I shone a torch on them looked OK.
I shot one sheet at 50 iso and the other sheet at 25 iso, they both look good, it was a test shot of the rear of my car shot out of my garage so not a work of art, but a satisfying result none the less.
Both sheets are drying, when they are dry, I will scan them and post them on here to get some views and feedback and to see if I need to tweak them in L|R or my process.
Ok this is the slide scanned in with my Z6 and the only thing I have done is white balance and blocked the number plate and added the frame, nothing else touched. Both shots are very much the same although one was shot at iso 50 the other at 25.
This look very good to me and can be processed more in LR or PS.
Very impressive. I wonder how this film would look in regular E6 chemicals.
Nas see this post, I used Tetanol Chemical Kit for this shot.
Very nice. I remember seeing that. Nice results from such old film. Cheers.
