- Oct 30, 2021
That could depend on whether you used any tilt or swing and where you put your plane of sharp focus. When I first started out in LF, I had to get to grips with movements, Merklingers notes came in very useful, especially the bit that talked about wasting the DoF on the plane of focus by placing the distant sharpness halfway up a building instead of following the ground. Although, in this case, I would have used swing to follow the line of the buildings. This, in turn, meant a larger aperture and less chance of diffraction.Image is just going out of focus on the top right hand side.
I had problems with slightly out of focus images when using f45. I bumped into Paul Barkshire one day (he produced two books of photographs of London using a 10x8 camera) and during our conversation I happened to mention the problem I was having at the time. He said it was diffraction and if I avoided the extremes of the lens, the images would be sharp. I tried and it seemed to solve the problem. From that point I have avoided using f45, especially with that lens, and it seems to have kept me out of trouble. I guess it is one of those habits which sticks?!
Paul
