Pyrocat HD precipitation problems
tykos
Hi, first post in this forum.
A couple of months ago I mixed Pyrocat HD for the first time. I needed a small quantity of it (100ml), so I had to measure very little quantities of phenidone and potassium bromide.
I solved this problem by creating a 1% phenidone solution in propylene glycol and a 1% KBr solution in water (I was not able to dissolve it in glycol, is it a thing?).
I then prepared my Pyrocat HD dissolving these and all the other components in warm propylene glycol.
Now, two months later, my Pyrocat HD has a lot of deposit and precipitation:
For what is worth, even my 1% phenidone solution has the same problem.
What could have caused this?
How can I solve it? I tried keeping the bottles in hot water and stirring the solutions, but no progress were made.
thanks
Michele
Consider switching to water-based preparation of Part A. If you use fresh metabisulphite while making Part A and store the concentrate in tightly capped glass bottle, the water-based concentrate should remain fine for a long time. I've some from four years ago and it is still good.
I used glycol because I read about it keeping for a long time and I mainly use other developers.
Do I have to throw it away now?
Probably not enough water to keep the Mertabisulphite in solution. You could measure what you have and add the same amount of de-ionised water. Then use twice a much Part A when using it.
Pyrocat HD PArt A keeps 3 to 4 years made up in water.
But I’ve got the same problem with the phenidone concentrated solution, and there’s no bisulfite in it
What concentration ? Typically it should be 50g per litre.
No need to throw it away. There are two solutions. The first solution is do what Ian suggested. Measure the volume of Part A that you have in the bottle and add the same amount of distilled/RO water to it. The precipitate should dissolve completely after water addition. Use twice the volume of the new Part A for the working solution. Test on non-critical film before using the new Part A on critical work.
The second solution is to heat water to ~80 C and place the bottle in the water bath till the precipitate redissolves in glycol.
(many months later)
i diluted my part A (which was mixed in glycol) with an equivalent part of distilled water and brought it all to 70-80°C. The sediments were almost all dissolved.
After a few days, no sediment like before but the mix is quite cloudy.
I didn't try this with my phenidone solution because i'm afraid it would go bad with water.
What could have caused all these problems? Bad/impure chemicals? Bad glycol? some procedural errors on my part?
