J
JAMESCF
Guest
I’m interested using Harman direct positive paper in camera. As the paper is orthochromatic (I have included the spectral sensitivity graph) I was intending on experimenting with using red filters for portraits for a more flattering effect. (As I don't have any experience with the paper yet I don't know how necessary this is but I tend to like this look compared to orthochromatic rendering of skin tones.)
My question though regards the use of filters with orthochromatic mediums in principle. It makes sense that the spectral sensitivity can be adjusted by raising the relative sensitivity through use of filters, but what if the paper is not sensitive in the range that is filtered for, will this have an effect i.e. you can't increase from 0. For example, referring to the spectral sensitivity graph, what would the effect of a 650nm filter be given that the paper has no sensitivity at this wavelength? Therefore would a red filter be recommended?
Thanks,
James
Thanks,
James
