- Nov 10, 2018
I thought about that but the hp5 sheets have always been spotless.That might suggest giving the holders a good seeing-to. I don’t mean to sound patronising, so I apologise.
Something else came to me after reviewing notes. Pinholes in the fomapan 200 emulsion. I've read about stop baths and not using stop baths and stop baths having nothing to do with it. Any thoughts or experience with this?Foma emulsions, film & paer, are slightly softer, less well hardened compared to other films, but handled carefully this isn't an issue.
All good advice. It's always good to review your techniques even if this issue lies elsewhere.For smoothing under the film rail, slide in the very finest emery paper you can find and slide into the groove and slide gently, gently back and forth along the slot. You might mount it on thin card. You’re only trying to remove irregularities, not grind them down so this is something you’d probably do only once in the lifetime of a holder. Clean up thoroughly afterwards of course. Slightly dampened cloth should deal with most dust, after a thorough blowing.
You can certainly clean the light trap, but that won’t affect film scratching.
You might review your own technique, if I may suggest it. When we insert film, we need to bend it upwards, to locate the film into the ends of the film slots. 5x4 film curves quite easily, but 10x8 is much stiffer. Could it be inadvertently scraping on the edge of the locking flap, as it goes in? Hard to tell in the dark.
This wouldn’t account for the invincibility of HP5, of course.
The Fomapan sheet film data sheet states not to use stop bath. I didn’t know this until fairly recently. In the past I’ve sometimes experienced random strange processing marks but since using water instead of stop bath I haven’t had any problems. I will be using water from now on with Fomapan films.Something else came to me after reviewing notes. Pinholes in the fomapan 200 emulsion. I've read about stop baths and not using stop baths and stop baths having nothing to do with it. Any thoughts or experience with this?
I missed this too initially but since discovered it. I also found a number of people sharing experiences of the pinholes not going away when not using a stop bath. I have a feeling I'm going to buy another box then call it quits with Fomapan if it doesn't come up to par. It's such a shame top feel this way as it has such a magical timeless rendering.The Fomapan sheet film data sheet states not to use stop bath.
Which developer are you using? Can you share examples of the pin holes you’re experiencing? Thanks.I missed this too initially but since discovered it. I also found a number of people sharing experiences of the pinholes not going away when not using a stop bath. I have a feeling I'm going to buy another box then call it quits with Fomapan if it doesn't come up to par. It's such a shame top feel this way as it has such a magical timeless rendering.
That’s fine. No rush. I’ve used HC-110 and Adox XT-3 with Fomapan 100 & 200 and so far so good. I keep my sheets cool but not in the fridge. You may be unlucky with a bad batch or there may be some other factors at play.I was using DDX and Rollei Supergrain. Stop bath was Adox. The pinholes are tiny little areas where there is no silver where clearly there should be. No discernible shape to them. Literally tiny specs - pinholes is a very fair description of them. I'd say with some confidence that they aren't air bubbles at that size. I think there's plenty of examples around. I'm currently archiving recent assignments and it's 9:30pm so I'm not going to dig them out right now. Sorry. I'll try and remember to do it.
Kind of got past thinking it's just a bad batch.
