- Sep 4, 2018
I used the same tank that I use for black and white, the chemicals seemed to wash out OK. Maybe using warm water helped here, I just used the sous vide water at first to rinse followed by fresh water and then the stabiliser at the end.Tempting... Do you use a dedicated tank for colour or can you use the same as for B&W ?
Slightly magenta but it’s just a colour balance edit. The negs look fine in colour.Nice !
Isn't the path slightly pinkish ?
