F/S: Wista [Japan] SW 5x4" Cherrywood Field camera (Detachable bellows x 2) with custom square masking ground glass £750
~RJ
Critique My Images
Yes
Beautiful cherrywood Wista of Japan 5x4 inch field camera with wide angle bellows and standard bellows allowing 47mm to 240mm focal lengths without top hat lensboards. Supplied with Wista's custom bright screen (clean) and groundglass.
The rear detachable film back holder has been customised to approximately 4 x 4 inch for a square large format negative. This can be removed by a carpenter. It allows square images to be made allowing a finger/thumb holding margin for developing and processing and avoids the mechanical vignetting problems of Nikon SW lenses with their limited coverage for 5x4 inch negatives.
Supplied as: 1x Wista SW camera, 1 set of wide angle bellows (up to 90mm Schneider XL lenses which the DX model cannot use due to its fixed bellows); standard bellows; ground glass and Wista fresnel screen and rotating modified 4x4 inch back.
Images available/viewing/demo/pick up possible at my studio in London. Will post at cost if tracked/recorded delivery.246953743_431525775270026_5381848859723945628_n.jpg
