Thanks David, also Safari 13.03. I don't want to fill the forum with my issues but as an update I have cleared my Safari Cache, all cookies and history with the same result. I think it may be a dns issue?
David, no the mac is hard wired to my router. The reason I think it may be a dns issue is that it works on my laptop but not on my mac. They currently are using different dns servers.
I only presumed it was Pre Catalina because I noticed you are running Bash in the Terminal instead of Z Shell which Apple has moved over to in Catalina
Final tests are under way on pre-packed Pyrocat HD, I've enough chemicals to make 20-25 litres of stock. Price should (will) be under £20 for a kit to make 500ml stock or 50 litres of 1+1 to 100 working solution.
I'll mix anything if I have the chemistry, could do many litres of Sulphide Sepai toner
Perhaps I should say I had a long conversation this afternoon with someone who has bought Pyrocat HD (a US kit) and found the weights of the chemicals in the kit were extremely inaccurate - we are talking huge discrepancies instead of 1g - 1.6g, more important the Phenidone was way off as well. He contacted the company who said what do you expect us to do ?
