Studio Flash advice
Discussion in 'Talk About Anything Photography Related' started by YorkshireBloke, Apr 22, 2018.
  1. YorkshireBloke
    YorkshireBloke Member Registered User
    Dec 20, 2017
    92
    8
    8
    Yorkshire, England, UK
    Hi,
    Yes, yes, I know, I am resisting the urge to buy gear. Honest.
    But thing is two projects I have in mind NEED. Yes NEED a stiudio flash setup.
    So any tips? Mistakes made? Help!? :eek:
    Robert
  2. Stephan
    Stephan Member Registered User
    Aug 10, 2016
    36
    17
    8
    IT System Engineer
    Heist o/d Berg, Belgium
    I guess the answer lies in what you want to use it for. In my amateur studio I photograph small objects so absolute power isn't necessary. If I would shoot maco and need to use small f's the choice would be different.
    Need to shoot outside? Interiors?
  3. Ian Grant
    773
    113
    West Midlands
    From your previous posts you indicated you needed quite a lot of light, I'd be looking for something like a Bowens Quad Pack and some heads, something more powerful than the average Monolight. Elinchrom kit is good as well. There are other makes that's just what I've used
    Ideally you want at around 750J output or more per head, you can turn power down if needed. Shooting for a catalogue a few years ago I needed pack with two heads and two additional fill in heads, that was to shoot 3 models.
    Luckily I have friends with commercial studios so can borrow flash kit when my own osn't powerful enough, I've also hired it which is not particularly expensive. Calumet is the best place for hiring equipment.
  4. Ian Grant
    773
    113
    West Midlands
    This is the sort of kit I'm talking about. An Elinchrom 404 pack with two heads, you could add a third. Total power output is 4,000 Joules which can be through 1, 2 or 3 heads, and plenty of control over the output. I've borrowed and also hired these packs and heads.
    In a small setting one person/model etc I can get away with using my two Elinchrom 250 flash units although I also use a Bowens Monolight 750, even with all 3 I've still only got up to 1250 Joules.
