Stouffer 21 Step Step Wedge
Discussion in 'Talk About Digital Scanning' started by Ian-Barber, Feb 4, 2017.
  1. Ian-Barber
    914
    197
    Doncaster (Yorkshire)
    I am conducting some tests with the Epson V800 scanner to see if I can ascertain it's minimum and maximum values in which it can resolve information from a black and white negative.
    The following is a low resolution version of the scanned step wedge which I scanned as a linear file (gamma 1.0) in VueScan and then converted it to gamma 2.2 for viewing.
    Each step of the step wedge represent 1/2 a stop and as far as I can make out, I can see tonality from step 2 up to and including step 16 which indicate that the scanner can extract an 8 stop range.
    The first step is film base which has a K value measured in Photoshop of 97% and step 16 has a K value of 8%
  2. Dewi
    Dewi Guest
    Dear Ian,
    Where did you get your step wedge from? In the UK?
  3. Ian-Barber
    914
    197
  4. Dewi
    Dewi Guest
    thanks Ian
  5. mpirie
    mpirie Member Registered User
    May 4, 2017
    145
    4
    18
    Highlands of Scotland
    I picked up a 21 step 5x4 version several years ago and intend to start testing film with it contacted together in a DDS......just need to get round to it.
    Need to dig out the densitometer too!
    PS there is a 31 step version that gives 1/3 stops instead of the 1/2 stops on the 21 step wedge.
  6. David M
    Jan 29, 2017
    664
    57
    South London
    This is interesting. What will the next step be?
  7. mpirie
    May 4, 2017
    145
    4
    18
    For me, just getting round to doing the tests ;)
  8. roncromberge
    roncromberge New Member Registered User
    Apr 20, 2018
    27
    9
    3
    Nederland
    This is not bad at all. I can see on this lowres picture 7 stops. Until step 14.
    Verzonden vanaf mijn iPad met Tapatalk
