Shutter problem
Discussion in 'Talk About Large Format Gear' started by James T, Oct 20, 2018.
  1. James T
    James T New Member Registered User
    Oct 19, 2018
    26
    6
    3
    Oxfordshire
    It was while searching for help on this that I found this forum.
    The lens that came with my Graflex, a Graflex optar 135mm in a Grafex shutter has a problem in that the "T" & "B" settings don't work (or at least do so only intermittently) instead it seems to fire at 1/25 (the slowest speed before the clockwork starts).
    Has anybody seen this problem before, and is it repairable -- and if so do you have any suggestions for where I could get it done?
  2. David M
    Jan 29, 2017
    1,127
    95
    48
    South London
  3. Ian Grant
    767
    111
    West Midlands
    As it's a Wollensak shutter it less likely a UK repairer will be familiar with it. I'd call Black on White in Bristol (I've used quite a few times) or Newton Ellis in Liverpool.
  4. James T
    Oct 19, 2018
    26
    6
    3
    Oxfordshire
    Thanks, I'll check those out.
  5. Alan9940
    592
    58
    Arizona, USA
  6. martin henson
    462
    207
    Otley West Yorkshire
  7. Diz
    Diz Member Registered User
    Aug 21, 2016
    79
    26
    18
    Co.Roscommon, Ireland
    I will second Newton Ellis in Liverpool. Used them quite a few times and been very happy with the service.
    Cheers
    Diz
  8. James T
    Oct 19, 2018
    26
    6
    3
    Oxfordshire
    I've found if I press the shutter release before letting go of the cocking lever, then when I press the release for real it works OK (bizzarre!)
