I've just completed mixing my first batch of 500ml each of Parts A&B Pyrocat-HD in water.
As expected, mixing B is noticeably exothermic and took a while for the Potassium Carbonate to fully dissolve.
What was unexpected was that the final/complete mixture of Part A had some precipitate in it that was resisting going into solution. It was a very small amount of dark brown precipitate, which I crushed as best I could but still didn't get completely into solution.
My "fix" was to place the mixing container for Part A into a tempering bath filled with water around 50C to raise the chemistry to the point I got most all the precipitate into solution.
Is this normal? Should I have mixed the Part A in heated water in the first place? Sandy King makes mention of elevated temps when working with Glycol but I found nothing to suggest this for the water-based formula, which is why I wonder ...
