Post Your Pyrocat HD Development Times
I am in the process of updating the Pyrocat website and want to add some film/development times from users.
If you could submit your own preferred times, that would be appreciated.
If you could submit in this format, it would help me to populate website more easily.
Film:
ISO:
Dev Time:
Dev Temp:
Agitation Type: Rotary/Tray/Inversion
Comments:
Dilution and film size should also be included...
Acros 100 (120)
EI 80
Pyrocat-HD 1:1:100
15 mins @ 21C
Small tank, continuous agitation for the first minute, followed by 10 secs agitation at the 3/4, 1/2, and 1/4 marks (10 1/2 min, 7, and 3 1/2 mins, respectively)
Provides enhanced edge detail
Acros 100 (5x4)
EI 80 (EI 50 is useful here, too)
Pyrocat-HD 1:1:100
10 mins @ 21C
Jobo 3006 drum rotating at slowest speed (CPP-2)
Fomapan 100 (5x4)
EI 80
Pyrocat-HD 1:1:100
9 1/4 mins @ 20C
B&W King stainless steel tank (very similar to 5x4 Nikkor tank)
Initial agitation of 4 inversions, followed by 2 inversions each minute thereafter
6 1/2 mins at 24C is a higher temp alternative
Fomapan 100 (5x4)
EI 80
Pyrocat-HD 3A + 2B + 600ml water @21C
Homemade tanks (ala Steve Sherman)
5 mins pre-soak, 2 mins initial agitation, followed by 5 x 3(15); 15 secs agitation each 5 mins for 3 cycles (17 mins total)
EMA (extreme minimal agitation) technique
Fomapan 100 (10x8)
EI 80
Pyrocat-HD 1:1:100
15 mins @ 21C
Tanks & hangers
Continuous agitation for the first minute, followed by 2 agitation cycles at the 3/4, 1/2, and 1/4 marks (10 1/2, 7, and 3 1/2 mins)
No pre-soak
Fomapan 100 (10x8)
Pyrocat-HD 8A + 5B + 1,295ml water (1,295ml total volume) @21C
I've included the specific Pyrocat formula because there are several available.
Let me know if any of the above is unclear and I'll do my best to help.
For tank development I use Pyrocat HD at 1+1 to 100 at 20º here in the UK, 27ºC in late Spring to Autumn when in Turkey.
All films except Fomapan 100 & 200 get shot at or just under box speed nad processed for 15 to 17 minutes at 20ºC inversion agitation, continuous for the firt 30 seconds, the a couple of inversions every minute. I use the same times for EFKE PL25 at its Daylight 50EI, and in the past Tmax 100 & 200 at half box speed, and the odd Acros at box speed.
Fomapan 100 & 200 are always shot at half box speed and processed for 12 to 13 minutes at 20ºC same agitation as above.
I find all my negatives print around the same times and contrast grade, I may shoot Delta 100 and 400 (120) and HP5, in the same sessions (or trips) and will develop them together in the same tanks. I ofte stick 120 Paterson reels in my Jobo 2000 tanks above the 5x4 spiral. I get very consistent negatives.
10x8 EFKE Pl25 at 50 EI and Fortepan 200 at 100 EI get dish processed with Pyrocat HD 2+2 to 100 for 9 mins at 20ºC as I don't like spending too long in the dark. Now though I have a Paterson Orbital so will go to 1+1 to 100 dilution next time I shoot the format.
DaveF
Thanks for this: interesting. I use Pyrocat HD for processing all my FP4+ on 10x8, to produce dual-purpose negatives for scanning and alt-pro. I also shoot B&W on 6x6 and 6x7 but use Delta 400 and DDX for that. I formally used Delta 100 and Ilfosol 3 or DDX for 5x4 but haven't shot any 5x4 B&W for a couple of years I think.
I use FP4+ at 125, use 2:2:100 with times usually now of 10'30" @ 21ºC for N with normal agitation - I have experimented with going a lot longer than this for alt-pro (esp. Argyrotypes) though with mixed results depending on a given negative (judging what times will work for processing given sheets for alt pro is a bit of an art I'm still trying to work my way through: so many variables with argyrotype especially). These times are perfect for scanning of course.
I use the new Steaman SP810 daylight trays for 10x8, which are excellent and a great improvement for my needs over the BTZS tubes which I still have and used until this year. (They need less space, and you don't need to go back into a changing tent to swap caps: I do all my processing in our small downstairs bathroom).
I then use Adox Acetic Acid (6mls to make up 500ml solution), I fix with TF4, and use Sodium sulphite hypoclear (1 heaped teaspoon for 500ml solution) replacing a given mix after 8 sheets.
There are only two things you have to watch with the Steaman trays: first, that you hold the lid firmly in place during processing because the lid just sits in place, not clip-on; second, the drain-time - on my current estimates it takes 18 seconds to completely drain 500ml of chemistry from the tray. Not really an issue for B&W but might be for the unwary intending to use these trays for colour processing where times are shorter and more critical (colour processing is very possible: I've not done it yet but will be experimenting quite soon hopefully).
[post updated to accurately reflect what my current notes tell me, even if for some I have been over-developing slightly]
DaveF
An update that I've now run a specific Argyrotype film & print test for this setup with 2 6x7 contact sheets (basically following John Blakemore's test process for Silver Gelatin) and my dev time is a too long by prob +2 stops and my FP4+ exposure is also perhaps predictably under by 1 stop (for this process). But for scanning this works fine
