Old exposed film
Nick Rowland
Hi,
Not large format but 35mm. I have found an exposed roll of Agfa Di-Direct 12asa reversal film that I must have forgotten to send off. It has to be 30 yrs or so old and used to have some sort of specialist processing by Agfa.
I am planning to try processing as negative film, my idea is to pre-soak in water and then semi-stand develop in HC110 (it's low fog) 1:160 for an hour. Anyone got a better suggestion, if not I'll just go for it as nothing to lose?
Cheers
Nick
James T
I don't know if this Flickr discussion is applicable:
Nick Rowland
Thanks James, I did see that but it was hard to decide who was knowledgeable and who wasn't. When it was current the film came in a process paid pack and had to be sent to Agfa directly for special processing (I have no idea why I didn't). I know that no processing lab would touch the stuff, which makes me think it needed special chemicals and processing, along the lines of Kodachrome. I used to use it a lot but never understood its background.
I thought the safest method would be to process as a mono neg as that can work with all sorts of film. Its age is against success anyway :-(
Nick
Nick Rowland
Oh well, at least I tried. Did a pre-soak and stand developed in HC110 with normal fix. The film came out looking totally untouched, goodness knows what the original process was but it wasn't conventional.
Nick
