Netherton Tunnel
alexmuir
I take it this is a canal tunnel? It's amazing how the lack of surface movement, or reflected lights makes it look like a dry, circular tunnel. Only the matching stains on the brickwork give it away.
A very impressive image!
Alex
Going back to an earlier post on focusing, how did you manage to focus this?
I like the little dot at the end. Cover it up and the image loses something.
Yes it's quite a late canal tunnel, wide enough for boats to go in both directions, a tow path on both sides, it was originally gas lit. I was a little way into the tunnel, closer to the entrance would have caused exposure issues.
The tunnel's 9,081 feet (2,768 m) long hence the little dot at the far end, it's crossed by another canal at a higher level at the north portal.
I focussed the camera closer to the entrance then went further inside.
Very cunning. Thank you. I presume you could then have moved further in and made another image, but walking round in bigger circles.
