Intrepid results.
Discussion in 'Black And White' started by David M, May 5, 2018.
  1. David M
    Jan 29, 2017
    1,133
    95
    48
    South London
    I've had my Intrepid for a while now. Here are some results.
    The flowers were taken indoors They are artificial and the original scan shows the texture of the fabric they are made from.
    Intrepid 10x8, Fomapan 400 rated at 200. Ilfotec HC. Nikkor 360mm f/6.5, at f22. About 12 seconds. Natural window light. The right hand side is burned in.
    This was to try the rear tilt. Focused without a loupe to test the clarity of the screen. As you see, the patio is overdue for its Spring clean.
    Same lens, same film, f/32 1 second. The leaf at top centre is burned in.
    I wanted to try out limited depth of field. Same lens, same film but wide open. Focus on one petal. I forget the time, but it was quite long.
    The vase holding the flowers was invisible to the eye behind the banister uprights, but they seem to have been blurred into transparency. That was a surprise.
    I am trying to wean myself off obsessive spot-metering so all these are incident-metered.
    Stephan and Stephen Batey like this.
  2. Alan9940
    592
    58
    Arizona, USA
    I really like the first image, David. Nice!!
  3. Stephan
    Stephan Member Registered User
    Aug 10, 2016
    36
    17
    8
    IT System Engineer
    Heist o/d Berg, Belgium
    I like the 3rd one, it is something about the atmosphere. The first one is great too, nice tones.
  4. David M
    Jan 29, 2017
    1,133
    95
    48
    South London
    Thank you.
