Epson R3880 Ink Delivery Repair
Discussion in 'Talk About Digital Printing' started by Ian-Barber, Aug 13, 2016.
  1. Ian-Barber
    851
    193
    Doncaster
    About 12 months ago, my Epson R3880 was starting to show signs of it dying. The PK cartridge was showing full on the display status but in fact it was virtually empty. To add to this confusion, I was suddenly getting blobs of ink appearing on the edges of the paper, not the kind you see from a wrong platen gap setting.
    After some web research, I was amazed to see others reporting a similar if not the same symptoms and eventually I managed to located the reason why which turned out to be a leaking seal in the ink delivery system. Unfortunately, this seal is part of a moulded unit and is not replaceable so the only option was to replace the entire Ink delivery unit.
    I created a blog post on my website with some pictures showing what I found.
    http://www.ianbarberphotography.co.uk/epson-r3880-ink-system-repair/
  2. Stephen Batey
    318
    58
    60
    None (retired)
    As a 3880 user, I find that very interesting. Thanks.
  3. Ian-Barber
    851
    193
    Doncaster
    Before I discarded the old ink delivery system, I did dissect it and the offending seal was where the MK and PK rocker arm was, the seal on on the PK side was deformed.
