Digital Negative Curves
Ive been spending some time experimenting with digital negatives contact printing with some very good results.
I quickly realised that it's not a one correction curve process, each type of paper and even batch of paper can have different tonal responses.
What I discovered was that although we send 100% black to the transfer film, by the time its gone through the darkroom process, we never actually wound up with 100% which is not surprising when you think about it. Even digital papers have their own characteristics.
What was needed was a method whereby we could in effect map the output from the inkjet printer to the output from the darkroom paper so I decided to work with an 11 patch step wedge for the mapping.
To help speed up the process, I decided to write a Photoshop action but this soon became awkward so I then decided to write a Javascript plugin and wrap the code behind a user interface. In theory, because this is Javascript it should work in Photoshop from around CS4 upwards.
Processes:
I only print using the Silver Gelatin process and have no means of testing it with any other processes.
There is more information and a quick video on my website
https://www.digitalblackandwhite.co.uk/digital-negative-curves.html
QTR (Quad Tone Rip) uses different ICC profiles to produce negatives for specific processes, a negative for Silver Gelatin printing isn't suitable for say Platinum Palladium printing. In addition negatives are optimised in terms of the colour inks/pigments used to give the best exposures with UV light, so for Platinum Palladium that' a greenish black.
The other feature of QTR is it lays down a higher ink density than the Epson print driver which is needed to achieve the higher density range required for most alternative processes.
Yes, I agree that other processors such as Platinum do require some form of blocking ink mask usually from the yellow which is why some tweaking of the script I made would need to be done in order to introduce this mix.
I am not convinced that the ABW driver is not capable of producing enough density at least for the silver gelatine process and the tests I have done have been very pleasing when setting the default tone option to darkest in the driver.
Presumably you could use the Cool/Warm/Sepia adjustment facility to control additional masking colours.
I would be careful introducing yellow because it's the most unstable of the K3 inkset. It would seem reasonable to think that the negative density could change over time. I don't know that we need to worry about keeping digital negatives for the long term, but I don't know how fast it might change...
Epson seem to make claims of up to seventy years for prints made with their inks. Presumably a digital negative would be stored carefully in the dark and might last even longer. This seems long enough for most purposes, but I may be misinterpreting things. I didn't find data for the specific longevity of ink on film.
martin henson
As a matter of interest Ian, how many hours work did you put in to make this, IMHO a very useful program (script) to have.
martin henson
I have been told by Ian over 100 hours work put into the whole project, all I can say is well well done that man and hope you can sell a few to help with the time involved.
