Dahlia - Pyrocat Extended Minimal Agitation
Discussion in 'Black And White' started by Ian-Barber, Aug 25, 2017.
  1. Ian-Barber
    1,051
    214
    63
    Doncaster (Yorkshire)
    This photograph of a Dahlia Pompom was developed in PyroCat HD using the Extended Minimal Agitation process taught by Steve Sherman.
    Although Steve Sherman primarily uses Ilford FP4 film, I only had some FomaPan 100 at hand so all bets were off as to what going to happen. I decided to use his FP4 formula as a starting point to see what changes I needed to make from there.
    Subject:
    I chose to make a photograph of this Dahlia Pompom at a local garden centre.
    Metering:
    The difference in exposure from the centre of the flower to the outer petals was reading 3EV on the light meter. I chose to place the centre of the flower on Zone 3 which would make the outer petal fall on Zone 6 (3+3). As I wanted the outer petal to be on Zone 8 I decided I would do an N+2 development to move the Zone 6 to Zone 8 without influencing the shadow values to much.
    Exposure:
    The final exposure including bellows factor was 1/4 second @ f/32
    Development:
    The negative was developed in PyrocatHD for 39 minutes @ 21°C using the agitation scheme from Steve Sherman's documents.
    Dried Negative
    This is a photograph of the dried negative on the light box
    Scanning
    The negative was scanned at 2400 ppi using Epson Scan software
    Scan & Adjusted Image In Photoshop
    Diz likes this.
  2. mpirie
    mpirie Member Registered User
    May 4, 2017
    146
    4
    18
    Highlands of Scotland
    Very nice Ian.
    I like the process change you've applied in moving the zones to suit your visualisation.
