Apertures, Shutter Speeds and Film speeds in 1/3 stops.
1/3 stop increments
  1. Ian Grant
    548
    90
    West Midlands
    Ian Grant submitted a new resource:
    Apertures, Shutter Speeds and Film speeds in 1/3 stops. - 1/3 stop increments
    Read more about this resource...
  2. martin henson
    400
    182
    Otley West Yorkshire
    Thank you Mr Grant, very useful numbers
    Regards
    Martin
  3. Emmanuel Bigler
    Emmanuel Bigler New Member Registered User
    Aug 7, 2018
    5
    0
    1
    Besançon, France
    Thanks to Ian Grant for the chart
    In addition, please find as downloadable jpeg image, a bar-chart showing the correspondence between the old series of speeds (e.g. on certain Compur shutters)
    1 1/2 1/5 1/10 1/20 1/50 1/100 1/200 1/400
    and the modern standard series
    1/2 1/4 1/8 1/5 1/30 1/60 1/125 1/250 1/500
    https://www.flickr.com/photos/43175600@N00/412475261
    The old series differs only by 1/3 of a stop to the closest value of the modern series.
  4. Emmanuel Bigler
    Aug 7, 2018
    5
    0
    1
    Besançon, France
    Another useful tool: a circular slide rule, a pdf document to download, ready to print and glue on cardboard, to compute at a glance the exposure values (EV) by 1/3 of a f-stop, when you are using very small apertures (e.g. f/500 with a pinhole camera) or very long exposure times (e.g. if you use a dark neutral grey filter).
    This slide rule, of course, is not an exposure meter (except if you consider that the "sunny-16 rule" is your favourite metering system ;) ) and does not take into account reciprocity failure, which has to be added; you should increase exposure times according to the film manufacturer's specifications for non-reciprocity.
    http://bigler.blog.free.fr/public/docs-en-pdf/2018-08-10-EV-circular-slide-rule_instructions.pdf
