I've just surfaced from the darkroom and a couple of hours printing and 2 excellent Exhibition images, there's something far more satisfying than making digital prints
For you maybe.
you are part way there as you processed E6
I also process B&W, using N+ and N- development where required, in order to obtain the very best negative for scanning, just as I would if I were making negatives for darkroom printing.
Over the years I've been heavily involved in Digital imaging mostly for work no way can I equate a little digital manipulation with the skills needed for alternative processes. We can play infinitum digitally with no or skill, there's always the undo button.
You seem to be saying that what I am doing is a "little digital manipulation", without realising the process I actually go through when I am creating a print from an LF negative.
Take this image :
It was taken by my friend Helen and she supervised the preparation of it for printing, not being particularly computer savvy herself. She started out by measuring the range of the scene and determining that it would require N-2 development; so she exposed it with that in mind and we processed the film accordingly. The small digital file shown here is unable to demonstrate that there is detail right down into the deep shadows as well as individual sprites of water being clearly distinguishable.
This took us around three evenings to prepare for printing. I started by optimising the scan, to give me the fullest dynamic range and greatest level of detail. Then I had to create around a dozen or so masked curve layers in Photoshop, in order to either accentuate or reduce contrast where needed. It involved the same level of planning and manipulation as if I had been using a multi-grade paper and head on an enlarger.
It also involves leaving the image to one side overnight to see if it still looks as intended the next day; then sometimes starting all over again because something isn't quite right.
A 30 x 24 print of that picture now takes pride of place on our dining room wall and is a subject of much admiration from visitors, both photographers and otherwise.
I can assure you that the sense of satisfaction in achieving such a result is every bit as great as when I used to do my own darkroom printing.
The big difference from darkroom work is that it doesn't cost paper and chemicals in printing test strips and even full prints, which can only be judged when fully dry. Or maybe it's because I don't have to throw money away on paper and chemistry that seems to raise the ire of diehard darkroom printers. Maybe they feel that it is important to not only spend time and expertise but, also to empty one's bank account. Or maybe it's because I don't have to torture myself going through the same printing plan every time I want to produce a print.
If I was in your shoes I might actually go down the alternative root, no enlarger is needed, you could easily make Digital Inter-negatives and then contact prints.
I can safely say that I have
never been interested in making small prints, even from 35mm film. One of the main reasons I got into LF was because I wanted to make extraordinarily large prints. To my mind, a 5x4 contact print is not worth the time, effort and cost, however minimal.
